Overclocking gone bad, need help....
Hello,
got weird problem, anytime I try to login to winxp it logs in and logs off back again… loops and never stops… Happened after I tried to overclock my ati videocard with ati tray tools software(tryed to move to much at 1 time- got out range screen, reboot and then loops started), safe mode or vga doesn’t help either .
have any ideas what can i do?
Tried removing the ati drivers from within safe mode? That would usually sort an out of range issue.
I can’t login in of mode , it same login/off loops.
Aha, not got a spare gfx card laying about or one built into the mobo?
nope
only solution i found and it worked-
from recovery console"c:\copy c:\windows\repair\system c:\windows\system32\config"
Glad to hear you got it sorted, my next step would have been to restore a few of those files but was out all day :open_mouth:
