P.c Problem
i have a p.c problem,anytime i use my p.c,after 5 minutes it turns off just like that and my p.c fan doesn’t roll/work,
this are the things i think might have been the problem,i downloaded speed fan,did some temperature shuffling,i downloaded c.cleaner(a registry cleaner,it erased a part of my anti virus and now my anti virus is turned off,but basically what i am concerned about is my fan not turning ,how can i fix this,should i re-install xp,or what ,I’m confused.please my p.c is my life.how can i make my p.c fan work please i need help
i tried system restore,but the system restore program did not come up,i use xp on hp,what could be the problem.
  1. Try to keep a cool head, although it’s not easy
  2. can you rotate the fan with your hand (to see whether it’s actually capable of rotating). If not - get a new fan, if yes - check the wiring to the motherboard - the connection might be loose.
  3. Which fan of all possible case fans is that anyway ? :smiley:
  4. Some sad anti virus you got there if ccleaner recognized it as trash :D. I’d suggest you use Avira, Avast or AVG - all of them have freeware versions for home use.
  5. Reinstalling windows should be a habit and done at least once a year. So, if you haven’t reinstalled it lately, do that.
  6. You can check the temps in BIOS. that’s more reliable.
  7. is your pc a desktop or a laptop?
a whole load of unordered questions, but those need answers so we can see where we are.
-i dont know but it is the one by the side and under
-how do i do that
-Laptop,hp compaq
No need to post twice…
That’s true. Therefore we continue with the other thread: http://www.hardwareforums.com/p-c-problem-26778/ :slight_smile:
