Panflo directional flow
i just recently installed my xp-120 with my M1A panflo 120mm fan. but i was wondering if the fan is facing the right way. the label panflow is facing up, visible to looking at it. is the label supposed to be facing the heatsink? thx bunches
here is the link to the view i have taken for u:
Yahoo | Mail, Weather, Search, Politics, News, Finance, Sports & Videos
its enough to just hold your hand over the fan, if its sending the air out, then its good if not then you can probably jus flip it over
There should be some arrows on the outside of the fan indicating the direction the fan is spinning and the direction of the airflow.
