Pc-problem
I have a PC with this information:
[ul]
[li]Os: windows 7- 32 biti[/li][li]CPU: Intel(R) Celeron(R) D CPU 3.06 GHz[/li][li]RAM: 4.00 GB (useable 2.94 GB)[/li][li]Adapter: Nvidea Geforce 9400 GT :[/li][li]Total memory grafics: 2271 MO[/li][li]Memory video dedicated: 1024MO[/li][li]Memory video syste: 0 MO[/li][li]Shared Mmory: 1247b MO[/li][/ul]
The problem with this PC is I can not even watch a video-clip on youtube because it’s so abruptly(a dont know the exact words- my english is weak) … so.. the videoclip intrerupt every seconds… The samesituation is with the game … even counterstrike 1.6 are functionaly abruptly … :frowning: … i dont know why it function like that …
I mention i did not have viruses … (i use kaspersky 2012 ) …
The problem with youtube is your adobe flash, this happens to everyone.. Adobe has not perfected a flash player yet that works right.. Next when playing ANY type of video games, you will need a Large video card…you might want to check your video card..
How ?
I have video controller VGA (VGA compatible) is that my videocard ? i think i have not a driver for this one … :frowning:
Do you have onboard video OR you are using a Card ? If you are using a card with default VGA settings, then that is your problem..
What is the make and the model of your card.? You probably just need the right driver …
I dont know what it’s mean …
again … I dont know
Im noob … i dont knew a lot of pc …
OK, look at the back of the computer … Now look to see if your Monitor plugin is at the top with all the other plugins or is it separate and more to the bottom ..
I see in your description you have a Nvida Gforce 9400 Gt, IS this right ? Where did you get this info ? If this is true, then you have a Video card…
You just need the drivers to make it work right..
bottom
yes… im sure 100%…
but that VGA what mean ? it’s need a driver?
Yea ! You need 32 bit video driver for Nvida Gforce 9400 gt…let me look..
Driver Downloads
lts nvidea driver for my pc :confused: … i have my nvidea driver newest than this driver…(version 306.23 the newest version of this driver)
if you ware that my driver is not compatibil …i assure you that it 100 % compatibil…
so?
So witch driver is your computer using ??? VGA or Nvida …
I have installed on my pc nvidea 306.23 … it’s a compatible version and the newest … but i also have something on my pc … VGA and i dont know what it’s !!! … It’s not really important … i only want to know why my pc are function so abruptly (youtube-clip and pc games…) … i have some friend that they own a pc weaker than mine and they dont have such problems…
Check your version of Adobe flash to there’s … All problems like hanging and lagging is from Adobe flash… As far as Video games, Most problems there come from Vider card…
