Hi there I ahve been having problem with my PC. It semms to just shut down and then I get this message appearing once the Pc has re-booted. But I dont understand what they mean can anyone help. Here are my PC specs
Intel Pentium 4 3GHz
1.5 G of RAM
NVIDIA Geforce 6600 256mb
M-Audio Audiophile 24/96 soundcard
Iwould be greatful for any help on the matter. Cheers
Yes but I have had this problem for around a year now I have taken my PC to get checked out and no one can find a problem with it. Thanx for the feedback.
As per donkey said… run a virus scan.
GO to http://www.hardwareforums.com/windows-xp-security-guide-9738/ to get the free virus scan softwares if you dont have one and thanks to megamaced who made our work easier. It will also give you some more security points which you might considering better.~!
Second thing to do is run a memory test (google for it).
