hi to all,
i am having a problem and need help to figure it out.
my pc swithches off autometically with no warning or error screen (like the power chord has been pulled off). Its a almost 9 month old PC.
The problem started along time ago which made me change my GPU and my MOBO.after which the system became stable. no problems at all .I could play all games without any problems. about 7 days ago i installed prototype and the problem started again. but only with prototype. but from yesterday onwards the problem occurs whenever my system is under a little or more stress.
i tried with all different drivers and OS(XP, Vista,Windows 7 and even linux) but same problem. i read the other post with similar problems and did a stress test with prime 95 and after 6-7 minutes while the test was going on the pc switched off again. the CPUtemp before the crash was 66 degree C. this happened everytime i ran the test.
My system specifications are:
AMD athlon X2 6000+
MSI K9N2GM FIH MOBO
9500GT 512 MB
2GB RAM
250GB HDD
450W power supply
any help will be highly appreciated . thanx in advance.![]()
