Pentium 3 motherboard question
Does anybody know of a good pentium 3 motherboard that is jumper less. Please help if you can.
Thank You
[QUOTE=efx2003]
Thank You
I had a great time with my CUV4X-C from ASUS. It was very stable.
Will that motherboard work with the TUALATIN cpu? And is there any overclocking features.
Intel II/III 300~1000+MHz Coppermine core is supported, i dont know about OC features yet!
Sorry, but I wasn’t into OC’ing back then. All I can say is that it served me well and contnues to serve my father-in-law well at his office. :slight_smile:
It’s not quite the same, but the TUSL-C uses the i815e and does support Tualtin chips. I’m not sure if the Abit SE6 does or not, but that would also probably be a jumperless design.
