Please help desperate!
i have been trying to make my comp for 2 months now and i come up with a problem everytime i finally got the power running after a month however now the display wont come up i took it to a mechanic and he said it was either the mobo videocard or PSU. so i bought a new of each and still same problem my ram matches my mobo. could it be the CPU?
Specs:
MOBO: Gigabyte GA-965G-DS3 S Series
Video:ATI RADEON X300 SE PCI EXP
PSU:600 Watt
Ram: DDR2 PC2 6400
CPU: Intel 2 duo core E6600
Which company is the PSU??
Also check if there is a power molex connector on the video card which u havnt connected yet..
Btw, r u getting any beeps??
Thermaltake, the video card doesnt need a connection to the PSU, and no beeps
Do the fans keep spinning? Or does the system power off?
According to the info from GIGABYTE - Product - Motherboard - Overview, ur mobo has got integrated graphics…did u turned off that from BIOS first?? or have u tried that graphics instead of PCIe?
the fans spin everything turns on i just cant see meaning i can mess with the bios settings i have tried 3 different video cards all brand new and still nothing i have tried 3 different mobos still nothing 4 different PSUs still nothing
use.. Memtest86+ - Advanced Memory Diagnostic Tool nd see if ur RAM is ok..
