Dear Champs,
hope you all are going great guns.
i am here for the solution of my pc problem and i expect i will be provided proper and right solution.
PC Configuration:
CPU: i7 3770
Mobo: p8h77 mle
Cooler: CM hyper 103
Ram: Hynix 2x4gb 1600mhz
GPU: Asus GTX 760
PSU: Corsair RM 750w 80+ Gold
HDDs: 2tb Seagate +1tb Seagate + 128gb SSD Samsung sata 2 (All HDDs are on AHCI mode)
Casing: Corsair carbide 200R (4 led fans 120mm installed) (2x Front intake, 1x Rear Exhaust, 1xTop Exhaust)
OS: win 7 64bit (installed on SSD)
i have been noticing that my PC freezes for a few seconds, mouse cursor moves but appears to be round circle rotating instead of arrow, and after upto 20 seconds everything works normally, it usually happens after starting PC, after using PC for a few hours, this problem goes away..
when PC freezes, only window elements dont work, get hangs or work very slowly like window environment, desktop area, or drive area etc. while if browsers are opening they work fine..
My window is installed on SSD (C drive), while my all other data is installed on 2tb HDD, because whenever i install any game or software i choose the F drive(2tb drive)..My 1tb drive (D drive) is attached, but empty and formatted, there is no data in it, but it is working, only HD tune pro shows in health tab, 2 errors about some minor bad sectors with yellow filled color and a red filled about hot temps, but this drive test results are fine and perfect on seatools and temps are always around & between 29c to 36c, so i think (not sure) that this HDD isnt causing this freezing problem,because it is not used, there is no data in it, but it is attached and enable..
2tb HDD and SSD shows the perfect result on HDD tune pro and seatools…
i tried to run my PC on on board graphics without enabling GTX 760 so i found same problem, means GTX 760 isnt causing this issue..
i changed mobo+proc+ram (i5 2400+p8h67+kingston 2x4gb 1333mhz), used for a few days and found same problem.
my power supply is brand new 80+ gold 750w, so i don’t think so it is causing the problem..
Please help me..and sorry for long post, actually i had to explain in detail so that helper can help me easily by understanding the entire scene.
PC has only this issue of freezing for 15 to 20 seconds, (Apart from this PC runs fine, i play games perfectly and do everything) when it happens casing LED light next to power button light, which blinks usually, stops blinking and remains turned on:
please guide me how can i resolve this issue, if you want to ask anything please feel free to ask
Thanks a lot
