Dear all
I have Intel d845gvsr motherboard with 256mb ram and the problem is when i switch on the system no display in monitor red led is
flashing in front panel. I opened the cabinet and removed the ram
and again i switch on it beeps 3 times with 2 sec time difference
and it stops the beep itself, i cleared the cmos by removing the
battery removing the jumper and the changed the working memory stick
in slot but the same indication is repeating.
When i remove the ram and switch on the system it start the power
on self test (POST). First test goes to ram if the ram is not
available it beeps for 3 times but if the ram is available it
does not beep and does not boot.
I cant understand whats the exact problem but i guess may be
the onboard video card is failure but im not sure.
Please let me know your ideas suggestion and is much appreciated.
Many thanks in advance.
Ranjith
