Im not sure if i,m posting in the correct catagory but here goes.
I left my pc on overnight and everything was fine turned it off in the morning and then when i went to switch it back on it doesn’t work.
I get power and the fans are running fine hard drive won’t boot moniter acting like the pc is turned of (just says no signal) and cd draws won’t open (if i leave for an hr or 2 cd draws will open and then when i switch it off again they won’t) anybody got any ideas please please help.
Then what I would do is strip everything out, except the motherboard, and see what happens. See if you can get some beeps at least! Even try powering up without a CPU first, gradually adding parts to see if it makes any difference. If nothing works, then I would suggest a faulty motherboard, but don’t take my word for it.
