Pls help me ... Urgent
I facing a problem on my CD/DVD drive,
my CD/DVD drive able to read and burn DVD-rom but once i insert a blank CD-rom, i can’t write any data in the CD-rom. I need to write some important infomation to my client.
Pls help me… :frowning:
Check how much data you are trying to burn on ur CD…is it more than the space available? also before copyng stuff on the CD first you can always check in your my computer on how much space is free on the CD.
Hi Karanislove
Thanks for the advise.
The data i need to burn is 128M and the CD is 700M which is more the enough, but i still can’t burn.
Pls advise me more on the trouble-shooting..
thx
how are you trying to burn the info to CD ?, presumably your using XP SP2, have you tried CDBurnerXP or are you using XPs native CD burning capabilities ?
Edit: CDBurnerXP is free
Hi Donkey42,
Sorry tat i never indicate wad software i use.
I’m using Nero Software.
The DVD/Cd burner is still new.
Abt 3-4 mths and jus only facing tis problem tis few weeks.
Is there any info you still need ?
hope tis info can help you.
Thanks
what media are you trying to use ?
the best brand is TDK IMO
also the internal burning laser could be out of alignment or broken
because i think they use a different laser to burn disc’s as they use to read disc’s, if i remember correctly
try some TDK media & failing that replace the drive, or burn the info to a DVD
Check the burning data on your cd.. It should be upto limit…
