Plz Help
My other computer is a Sony Vaio Computer. When I tried to use the keyboard and mouse they didnt work. They used to work fine when I first got it. Now im always stuck in the log in screen when the computer starts! I cant do anything. I changed the batteries 4 times. plz help.
Thx
Since you mentioned batteries I’ll assume your keyboard & mouse are wireless.
  1. Try plugging the base into a different USB port
  2. Ask a friend if they have the same make keyboard/mouse and test them on your base, if that doesn’t work then your base is pooched.
  3. Get someone else’s base and test your keyboard/mouse on it
Sry i dont know alot from computers, but what is a base. What it looks like?
Your keyboard & mouse are wireless, correct?
yes
The base for the keyboard/mouse plugs into the back of your computer tower, usually into the green and purple ports, or into a USB port. It should be fairly small, have indicator lights (some don’t) and have a ‘connect’ button.
Once you’ve located your base, press the connect button on it, then press the connect button on the bottom of your keyboard. Then do the same thing again, press the connect button on the base, then press it on your mouse. See if it works.
ok thx alot!
MAN!!! sry but the keyboard still doesnt work
Did you press the connect button on the base and THEN the button on the keyboard?
yes, I pressed the connect button on the keyboard.. only the standby button worked.. not any numbers or letters.
Did you ever spill anything, or thought someone spilled any liquid of sorts on the keyboard? Did you change the batteries to known good ones?
not that i know of..
which batteries should i put?
The keyboard should accomodate either 2 OR 4 batteries
yeah it needs 2 batteries
Ok..just make sure the positives and the negatives are lined up.
yeah they are lined up.. why does only the standby button work??
not a clue. your keyboard might be toast.http://www.toaster.org/cards/toast.jpg
ok thx anyways
Try using in a different Computer. If it works that will make you sure that your Keybord is fine.
