Points System
OK we have new points system for our forums :slight_smile:
1 Point For A Post (Reply)
2 Points For Starting A Thread
3 For Referring A New Member
thats about it, to see your points, you have to have private message feature on currently, but I will have that fixed very soon.
What Can You Use The Points For ?
In the near future, you may enter the points into contests, the more points you enter the more chance you have of winning.
Soon, you should have the ability to see how many points other users have, or maybe a little hint instead :slight_smile:
Plus More :smiley:
btw: I am aware of the little bug, that the amount of posts and threads since your last visit are the same, will have that fixed. asap…
Sounds great! Cheers -=Sniper=-
CHECK THIS!!!
I know its in the wrong forum, but Its urgent, TLM ltd computers in Morley Leeds, are selling the AMD XP 1600Mhz chip at ONLY £120, I have put in an order for an upgrade!
DIRT CHEAP!!!
their website is never updated!
ever thing should work now :slight_smile:
for now on please dont take notice of the points you have, they will be be reset so they only count from a certain day, as soon as I can figure out how it should be done…
