Power Diagnostics
Ok Ive got a antec 430W PSU and know that it supplys my system with enought power.
But im curious to know exactly how much power is being used (LOAD)
Does anyone know of any free software that can tell me his information? :rolleyes:
Well, you should be able to get the information you need to calculate the power (which is measured in Watts—W) from the uGuru software if you’ve installed it. The problem is that it’s likely reading this information off BIOS sensors, which aren’t the most accurate. To get the best readings, you’ll want a multimeter, and then calculate it. The thing is, I don’t remember what the calculation is…
Basically, there’s not some monitoring software that measures power for you. The things that are monitored are temperature and the voltages.
