The power light connection for my antec p160 case is a 2-pin connection. The motherboard that I have needs a 3-pin connection. The motherboard diagram shows 3-pins, the pin on the left is positive, the middle pin is blank, and the right pin negative. How can I fix this problem. Please help If you can.
The power LED doesn’t need all three pins. One of those pins is for a different colored LED (for sleep mode). If you pull the copper pins out of the plastic casing on the LED cable, you can place them where they need to be on the motherboard header.
