Is it possible to repair or replace a broken ‘Power-On’ button on a PC’s case and perhaps the wiring that connects it to the motherboard? Or, is it necessary to buy a whole new case?
Many thanks,
David.
Many thanks,
David.
[QUOTE=DavidNW]
yeah, you can if you can repair it although, it’s easier to just replace the power switch , just disconnect it from the mobo & disconnect the switch from the back of the case’s front panel, do any necessary repairs, you don’t actually need a power switch, you can however, briefly short the two pins that the power switch plugs onto to turn the system on
Edit: just use a screwdriver tip to short the pins & leave it connected to the pins for 3 seconds to turn system off, as you would with the power switch
Thanks, Dave.
I was just thinking how it could be achieved because a friend of mine says his ‘Power-On’ button has inexplicably cracked! He must have been very ‘heavy-thumbed’, so to speak!
[QUOTE=DavidNW]
no probs, i like easy to solve problems, although, it must be about 10 or 15 years since i replaced a power switch, good job they haven’t changed, cos it not very easy to mess inside my system now
The power and reset switches use a momentary push button switch. The likes of Radio Shack or similar stores should have them.
