Hi people. I’m having a problem with PowerPoint. I know how to add a sound file to a slide. But how the heck do you add a sound file to the whole presentation
.? I’ve been pulling my hair for 2 days now :eek: . I’ll really appreciate if someone could tell me how to add a sound file so that it plays throughout the whole slide show.
Thanks gang.
I’ve only used powerpoint twice, but I tried to learn as much as I could about it as I can. If you’ll give me two days I will be able to get you a positive answer. because I in two days I have a class and we’re working on power point presentations. I’m pretty sure you can only attatch sound files to a slide or they are triggered by a click.
You know, I received a presentation by e-mail, and it played a sound file throughout the whole slide show. It was a song. So, I know it is possible to apply a single sound/music file to a presentation. Anyways, thanks ninja, and see you in 2 days I guess. ![]()
It’s simple, insert your sound object then right click and press custom animation. The animation bar will appear. Click the drop down arrow next to ur sound file and click “Effect Options” simple from there :good: ( I want some rep points for this :chk: )
Have you tried clicking that annoying paperclip? ![]()
[QUOTE=Addis]
I just told im how to do it!
[QUOTE=Addis]
CLIPPY IS GOD!
“Clippy” sucks ass! I don’t need the likes of him to help me! :mad: hehe
I like ‘robby’ - the robot. Hes set as my assistant in school
I dont need assistants, they do my head in!
i know i hate assistants as well they never help you with what you need neway. Dave
I never use them i just right click and animate them when i bored in class
Haha, very constructive…i must admit i used to do it too :o
Lol ![]()
I hate those assistants too :mad: .
Ok, back to the topic. I finally figured out how to apply the sound file to the whole presentation. You just right-click on the sound you inserted, then select “custom animation”. When the task pane appears, just double-click on the sound file inside the task pane. A window should pop up. Just go to the “stop playing” section and choose the “after_ slides”, and enter the number of slides you have in your presentation. That will make the sound file play all the way to the end of the slide show. :agree: Oh yeah.
Anyways guys, thanks for your help.
I liked Einstein in Office2000 but they replaced him with that gay wizard.
[QUOTE=dannnyjos]
Thats exactly what i said!!!
Yeh i used to like Einstein too
