Hi, I know this is probably a really dumb question, but being that i’m not 100% sure I don’t want to screw anything up. I just installed a new Super Flower 520W Power Supply in my PC and the power supply has a switch on the back with three different fan speed options. One is normal, two is low and three is high.
The question though is it o.k to change that switch while the pc is ON? With my luck i’ll change the fan speeds to find out and my power supply will short circuit, lol.
My hunch is that it’s alright, but I just want to make sure otherwise I’ll power down the PC first and then adjust the fan speed.
Thanks much in advance to anyone who replies.
