I have had problem with my machine for a while now.
During start up it reaches a certain point then does a number of different things;
1).Turns off completely so i have to press the power button to start again
2).Resets itself and returns to the beginning of the start up process
3).Stays at a black screen with the power still to the machine and doesn’t go any further.
It has on occassion turned off during mid session but this has only happened a handful of times.
The spec is as follows:-
Abit KD-7 Motherboard (not KD-7 RAID)
AMD Athlon XP2600+ 2.08Ghz
DDR333 Samsung RAM 2x1GB
Radeon Ati 64mb Graphics Card (AGP)
IBM Deskstar 60GB Model No. IC35L060AVVA07
Window XP Pro 2002 (official registared copy)
PSU CTK Model: LC-B350ATX Output: 350w
Bios Temp and Voltage Readings
CPU Shutdown Temp - 70c
Shutdown when CPU Fan Fails - Enabled
CPU Warning Temp - 60c
System Temp - 44c
CPU surface Temp - 36c
CPU Core Temp - 48*c
CPU Fan Speed - 2360rpm
CPU Core Voltage - 1.66v
I/O Voltage - 3.29v
+5v - 4.99v
+12v - 12.03v
AGP - 1.53v
DDR SDRAM - 2.57v
Standby Voltage (+5v) - 4.89v
Battery Voltage (+3v) - 3.16v
I also did have a PCI graphics card in it to run two monitors but this has now been removed (i had the problem before this was removed)
I have checked the Capacitors on the motherboard they all look clean and fine. i have also tried different memory and graphics card.
Hope this is enough info!
