printer problem
I have a problem running a design program and have found out that it works ok when the printer is not plugged into the pc(usb port) but when i plug the printer in i get this message:- FPWIN3D caused a general protection fault
in module DESIGN.EXE at 003e:00001452.
Registers:
EAX=c0030000 CS=36c7 EIP=00001452 EFLGS=00000246
EBX=000103e2 SS=2527 ESP=0000f924 EBP=0000f93e
ECX=00020000 DS=2527 ESI=000203e8 FS=05b7
EDX=81950009 ES=0000 EDI=00000000 GS=0000
Bytes at CS:EIP:
26 ff 77 02 ff 76 08 ff 76 06 c4 5e 06 26 8b 1f
Stack dump:
f9300017 1d4c60e5 00040a2f 050ff93f 03e236c7 0002490f f9750000 11bf1df2 490f03e2 000003e8 02990380 00df0004 4855f964 000017d7 2527fa9e 00028118
I s there any way I can resolve this?
This is very likely a software problem as the GPF indicated, I’d install the latest printer drivers for your printer from the manufacturer’s website.
Also try removing any applications that start up when you plug in your printer. So just have the drivers installed.
