Sorry if this is the wrong place for this question. I have down loaded a active x plug infile to enable the viewing of a particular web cam. When trying to open I get the message un able to open. Try getting explorer to open no go. Try on line to be informed I need a ocx file. but unable to locte one for windows xp2. Any help welcome.
Why do you need it to view a webcam?
ActiveX is dangerous, as it presents many security problems and downloading unknown activex controls is definately not recommended.
Hi, For some reason Weymouth council webcams require you to have this active x explorer plug in for their cams to work. normally on first vist to the cams this plug in down loads and installs. Mine has downloaded but my system is lacking something to enable to install. Active x is safe if from a known site and approved. ie. Java. Only dangerous from dodgy sources ie. porn sites.
Go to Device Manager and see if there is any yellow exclamatery sign over there…
Hi Unable to work out how to check this one. Running xp2. Please advice in simple idiot guide.
Device Manager (RightClick MyComputer > Manage >UnderSystemTools, you will find Device Manager)
Check if there is any yellow exclamatery sign…
Also please let us know the model number and name of your web cam…
Hi Trying to view Weymouth and Portland Borough Council web and internet enabled cameras and web cams
to do this i need xplug. ocx from cellvision systems inc. the activex control.
Normal when you first vist the web site of weymouth cam. you are asked if you want to install. this does not happen with me as the plug in is already on system but not working. I have tried un installing with out success.
I cant visit their website coz I’ve got IE7, which they doesnt support. Anyways, did you read the manual before installing the drivers for your Webcam? coz there are sometimes when you dont connect your product before installing drivers…
I would suggest you to try this…
Go to Add Remove Programs in your Control Panel and remove every software relating to your Webcam. Then go to device manager as I stated above. If you see any driver related to your webcam then remove that as well. Remove the webcam. Insert the drivers CD, install all the drivers carefully. While installing if software requires you to plug in the Webcam then do it but if it doesnt then dont. After installing drivers, restart your computer. Plug in your Webcam and see if it detects… Good Luck
Hi Think you may have mis understood me. It’s not my webcam but Weymouth council It should work on IE7. I been trying to solve this one for a age.
I’ve installed the Active X and it won’t work for me either…Do you know somebody who can access as it might be a prolem with their site.
Hi , I had a guy on another forum sit whom managed to get the cams to work. I cant on this computor and my son has tried two others with out success. Have e-mail and rung Wemouth council with out any joy.Would like to crack this one as It is driving me mad!!.![]()
Hi all ,Still not sorted this one. Any ideas besides give up?
