Problem when turning on computer
Hello everyone,
When I try to turn on my PC, it looks like the computer is working;
The fans work, the light bulbs are lightning but nothing goes up on the screen (and it doesn’t make the beep sound)
I tried to switch the power supplier but it didn’t help.
But when I turn the power supplier’s switch off, then turn the computer on,
and then turn the power supplier’s switch on again, and turin the computer on again, it works like nothing happened.
What is the problem?
Thanks.
My computer details:
[LEFT]
[FONT=arial][SIZE=13px]
Computer:
Computer Type ACPI Uniprocessor PC
Operating System Microsoft Windows XP Professional
Internet Explorer 8.0.6001.18702 (IE 8.0)
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name WINXPSP3
Motherboard:
CPU Type Intel Celeron 420, 1600 MHz (8 x 200)
Motherboard Name ASRock ConRoe1333-D667 (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video, Lan)
Motherboard Chipset Intel Lakeport-G i945GC
System Memory [ TRIAL VERSION ]
DIMM1: Hexon Tech. HEXON 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Type AMI (10/31/07)
Display:
Video Adapter Intel(R) 82945G Express Chipset Family (224 MB)
3D Accelerator Intel GMA 950
Multimedia:
Audio Adapter Realtek ALC888/1200 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Storage:
IDE Controller Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
IDE Controller Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Floppy Drive
Disk Drive WDC WD1600AAJS-00PSA0 (149 GB, IDE)
Optical Drive Optiarc DVD RW AD-7200A (DVD+R9:8x, DVD-R9:12x, DVD+RW:20x/8x, DVD-RW:20x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Network:
Network Adapter Intel(R) PRO/100B PCI Adapter (TX) (172. [ TRIAL VERSION ])
Network Adapter WAN (PPP/SLIP) Interface (77.1 [ TRIAL VERSION ])
Peripherals:
Printer Canon MX300 series FAX
Printer Canon MX300 series Printer
Printer Microsoft Office Document Image Writer
Printer Microsoft XPS Document Writer
USB1 Controller Intel 82801GB ICH7 - USB Universal Host Controller [A-1]
USB2 Controller Intel 82801GB ICH7 - Enhanced USB2 Controller [A-1]
USB Device Aladdin USB Key
USB Device Canon MX300 ser
USB Device USB Composite Device
USB Device USB Human Interface Device
DMI:
DMI BIOS Vendor American Megatrends Inc.
DMI BIOS Version P1.60
DMI System Manufacturer To Be Filled By O.E.M.
DMI System Product To Be Filled By O.E.M.
DMI System Version To Be Filled By O.E.M.
DMI System Serial Number [ TRIAL VERSION ]
DMI System UUID [ TRIAL VERSION ]
DMI Motherboard Manufacturer
DMI Motherboard Product ConRoe1333-D667
DMI Motherboard Version
DMI Motherboard Serial Number [ TRIAL VERSION ]
DMI Chassis Manufacturer To Be Filled By O.E.M.
DMI Chassis Version To Be Filled By O.E.M.
DMI Chassis Serial Number [ TRIAL VERSION ]
DMI Chassis Asset Tag [ TRIAL VERSION ]
DMI Chassis Type Desktop Case
DMI Total / Free Memory Sockets 2 /[/SIZE][/FONT][/LEFT]
[LEFT][/LEFT]
when does this start happening? is there a pattern to when it happens?
does it happen when you been using it, shut down, then try power it up?
or does it happen when not using it for a while and turning it on?
or does it happen anytime when you shut down or not use for a long time?
or does it do this randomly?
also when it does have the problem do you always get power light, fans running, etc?
also when it does have the problem i know you said you have no video but can you see the hdd light (red usually) flickering or hear the hdd like as if its loading windows?
do you have a spare video card and/or memory you can try?
if you have a spare try them out and disable the onboard video to see any difference.
otherwise go in the bios and disable all onboard items such as sound, lan, serial ports, lpt ports, etc.
disconnect all your cables except the power supply cables that go into the motherboard.
remove all the peripheral cards if you have any. disconnect even the usb/1394 cables that go into the motherboard.
then see if you still have the issue. all this is to isolate the issue from being anything else other than the motherboard.
This can be a number of things, Motherboard going out , video card going bad or the power supply… You will have to narrow it down… try the Video first..
Check your card And Monitor … try A different Monitor.. Have you download anything New lately ?
