i have a faint memory of writing about this before, but i looked in subscriptions and could not find it.
when i go on a game, i set the in game reseloution to 1024x768, and my normal resolution on the desktop is 1152x864, but when i exit a game, the resolution is changed from 1152x764 to the ingame resolution, why is this happening, i have the latest graphics drivers.
also with a game like hl2 it took me ages to get the in game resolution set to 1024x768 becouse it kept saying failed to set video mode, and some times a memory error came up.
i hate 1024x768 resolution on the desktop, so why does the ingame resolution end up on the desktop too, as i have not changed it in display properties, but when i look in display properties, it is at 1024x768, i have even tried to restore the computer to fix this problem, but i failed.
its more than anoying now, becouse, it wont let me play hl 2 at all, keeps saying could not set video settings, then sometimes the screen just turns into little rectangular squares, and is like a mozaic.
hmmm, if i instal the latest official radeon drivers, or omega drivers, then there is still a problem, but if i install the drivers i got wit my graphics cars wich are version 8.4 or somthing, and are months old, then half life 2 works perfectly.
can you make anyhting of this??
i event manager i see that there is quite a few errors wich are aplication hangs, and all of them are half life 2, so i suspect this is when half life 2 exits.
thats the error log.
Event Type: Error
Event Source: Application Hang
Event Category: (101)
Event ID: 1002
Date: 29/07/2005
Time: 13:13:54
User: N/A
Computer: SUICIDE-567
Description:
Hanging application hl2.exe, version 0.0.0.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
For more information, see Help and Support Center at Microsoft Support .
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 48 61 6e 67 ion Hang
0010: 20 20 68 6c 32 2e 65 78 hl2.ex
0018: 65 20 30 2e 30 2e 30 2e e 0.0.0.
0020: 30 20 69 6e 20 68 75 6e 0 in hun
0028: 67 61 70 70 20 30 2e 30 gapp 0.0
0030: 2e 30 2e 30 20 61 74 20 .0.0 at
0038: 6f 66 66 73 65 74 20 30 offset 0
0040: 30 30 30 30 30 30 30 0000000
i have restored my computer loads of times, and am using the graphics drivers windows installed, and the problem apeard ot be corrected, but now i see its happening again with the reseloution not bieng right ^^^^^
[QUOTE=willhub]
if you have a Radeon set the res using the control panel aswell as the display settings ! 5.7 Drivers are ok if certified !
ok i found out what was causing my reseloution to stay same as game, i dont know if someone knows why it would of caused it but i would like it if someone could tell me why it happend.
well i got this program called sysmetrix from wincustomize.com, it has lots of system statistice on and starts from start up, now if i have it on and go into a game with it on it makes reseloution stay same as in game, but if i turn it off, i can change reseloution withought restarting computer, and games work ok.
i dont understand how a small program could do this, perhaps someone could shed some light on it :.
