hey guys, i been using this card for bout 3 years…(dont ask=dell)
well…bout 30 mins ago windows gave me an update, a driver update for the graphics card, anyway, after i installed it and restarted the colour depth became 4 bit. Which i never knew was possible, i also cant change the resolution from 800x600. Can someone please help.
go to the device manager(Right click Mycomputer>manage>Device manager)
Select your graphics card, double click on it. Under Drivers tab, press RollBack driver. Restart your computer…
Edit: Previous step will take you back to your previous Graphics driver. To install new drivers again, go to device manager, right click on the Graphic Card > select update. Make sure you are connected to the internet. If you experience the problem of colors again then Roll back your drivers and leave it as it was…
thanks a lot, but just b4 u posted taht…i downloaded the updates from nvidia…the newest driver and installed it. Problems over, thanks a bunch tho..i didnt know how to rollback till u jus said that :P;)
