problems with WDS
hey ino this could be in the wrong section but the thing is that im a IT techie for the school im working at and i killed my server that had server 2003 setup for RIS and now i had to use server 2008 and on that im tryin to setup WDS (windows deployment service) and my problem is trying to create the .wim file type for XP pro ive had a fairly good look at in on the internet and they all seem to say different things and i was wondering if anyone on the forum has used it and got it to work could tell me how they have setup theirs
thanks for your time ash
Server Side: WDS settings
Open WDS console and right click on Boot Image folder and select Add Boot Image. brows to Vista (x86) Boot.WIM file (it has to be x86 version as you are going to install XP which is x86 architecture. for the sake of confusion call it “Install”. Let WDS add the image.
Right click on “Install” and select Create Capture Boot Image. Call it “Capture”, you can rename it after.
Right-click on Install Images and select Add Image group. Call it XP Images for the sake of this setup.
Client Side: Image Capture
Run setupmgr from XPcd\support tools\deploy.cab. Create a fully-automated Sysyprep answer file. save it as c:\Sysprep\Sysprep.inf
Run sysprep.exe, select Reboot, Mini-Setup and click on Reseal.
choose to pxe boot when it reboots.
choose “Capture” image and let it load up.
follow the wizzard through. (file name, description, location etc)
choose to upload image to server tick box and type in server name (only the name should do it)
it should ask you for credential ([email protected] format as username, wds can’t take short name for some reason)
select Image Group and that should get you going to capture an Image. As far as I know this Image will be deployed without any errors. i think your are having problem with the Image because you used ImageX to create image. I may very well be wrong. Try using WDS throughout the whole process.
Client Side: Image Deploy
boot to PXE and select “Install”
choose country and language
provide credential
choose Image
choose disk/partition. At this stage it should install the Image you captured using the “capture” wizzard and answer all question from that Sysprep.inf you saved in c:\Sysprep\ folder
Deploying XP using the WIM format on native WDS server - TechNet Forums
ive tried but on the client pc when i go to reboot after using setupmgr it goes to pxe boot spends a few minutes trying to find the boot file then loads up xp and it done that the 3 client pcs i have tried
thanks for the reply
ash
