i would of thought vga.sys was something to do with graphics drivers or something like that. is it a copied version of windows, and have you formatted it or upgrading (i would format) + whats ya pc spec. hope this helps post backe Dave :good:
yea using a copied version cud be a problem try installing the compact version and this might bypass this particular file if not try and get a different copy hope this helps Dave :good:
