Hi guys, had a good read through the forum to see if this had been covered before but could’nt find anything the same so sorry if it has been covered already.
I have recently bought a new 6600GT G/Card but after installing had a problem! Every 2 days or so the fuse in the power lead blows and i have to replace it, this always seems to happen whilst i’m on Battlefied 2.
At the time i was running an XP2600/Gigabyte M/B that was at least 2 years old so i thought i would go a step further and replace the M/B, CPU and Memory thinking it might be that. After the new parts were installed i found i had the same problem! I must admit that the PSU i am using is a cheap 400w called Q-Tec.
I have ordered a new PSU anyway (Enermax Noisetaker EG495AX-VE 485W) which i hope will be good enough.
Is this a typical PSU problem? or have i ordered the wrong part?
The problem is definately your PSU. In fact, we have a few dozen threads on this forum about Q-Tec PSUs and why you should avoid them at all costs. If you don’t have any system damage as a result, you’re one of the lucky ones for sure. You can get a Thermaltake 420 PurePower for about $35-US, I don’t know about on your side of the pond but I’d imagine it’d be relatively cheap there as well. We even have an article about PSUs stuck right at the top of the forum you just posted in: Power Supplies and You, or Why You Don’t Want a Cheap PSU
[QUOTE=unionjack]
Thanks guys, with any luck the Enermax should be delivered either tomorow or wednesday. I’ll be worried until i get the new one in now!
No problem, it’s what we do. As for the PSU, good choice. Enermax is usually my first recommendation if you have the cash for it. If you have strange issues after the new PSU is in, the old one may have damaged system components. Be sure and drop us a line if that happens, and we’ll help you to troubleshoot.
Just fitted the new Enermax and everything seems ok so far(30mins)
Could you just verify these stats for me please if you can? I took these from the Bios screen and wondered if they seem about right?
