hi everyone.
i am in the process of building a new system and i am not sure wether or not to install vista 32bit or 64bit. it would be a great help if anyone could advise me on what to do. has anyone got any problems with vista 64bit?
thanks, kris
hi everyone.
thanks, kris
i have a problem with vista full stop!
i would SERIOUSLY recommend that you stick with XP (and you can use the serial key from your old computer and even if you can’t do that you can get a new one for a pittance compared to vista),
your going to have enough compatibility problems with 32bit vista but at the same time, vista is so grossly inefficient that your most likely going to need the full 64bit power of your cpu to get it running okish.
