I am buying a new computer case that does not have any type of rubber groment to quiet the hard drive. Is there a web site that sells rubber groment. Or is there something i can get to quiet my hard drive beside a hard drive enclosure. Please help if you can. Thank You
No Vibes III is good, if rather large HD rubber thing.
if your pc is un modded (no windows in the side) theres like a rubber mat that you put inside which generally quietens down the whole system in general. Hope this helps Dave :good:
I will take a look at those items. Thanks for help.
