Hi
We have recently bought a supermicro( www.supermicro.com ) server with a 2U chassis and a P3TDDE dual cpu motherboard with no onboard video. The problem is that we also bought a 5 disk raid array that required a raid controller card. Since the raid controller card is too big to fit in a 2U chassis, we had to use a PCI riser card.
Now, the pci riser plugs into the first(highest) PCI slot and when we plug the raid controller in, it blocks all the other PCI slots. The riser has two(2) PCI slots, so, since we needed a video card, we plugged it with the raid controller on the PCI riser. But, it doesn’t work. When the raid and video cards are plugged on the same PCI riser, therefore the same PCI slot, they don’t work. We’ve tested them in the normal PCI slots with the case cover off and everything works perfectly, we were able to install windows and all that. But we need to close this cover and can’t. Is there any way we can plug the two in the same PCI riser? Is this some sort of IRQ setting problem? Is there any way we can workaround this problem?
Thanks a lot
Marc Tomkinson
