RAM Issue , i think lol
I just purchased this PC the other day from tigerdirect… i bought a new power supply 630 watt , a new video card sparkle 8500GT 1gb , and 4 sticks of ram (OCZ PC2 6400 1gbram x 4 800mhz) 4-4-4 @2.1v.
I installed everything and it didn’t work, so i took the ram out and put the stock ram back in ( PC2 5400 1gbram x 2 667mhz + PC2 5400 512mb x 2 667mhz ) and everything ran fine.
is there something i have too do too my BIOS? Im really not computer savvy more of a tinkering around hobby.
here is my motherboard specs , and then the whole stock PC.
Form Factor
* µATX Form Factor
* 24.4 x 24.4 cm
CPU Support
* Socket AM2 (940 pins)
* AMD Athlon 64, Athlon 64 X2 Dual Core and Sempron processors
* 2 GHz HyperTransport interface speed
Chipset
* NVIDIA nForce 430 Northbridge with Integrated Graphics Processor
* NVIDIA nForce 405 Southbridge
System Memory
* DDR2 800/667/533, 4 banks with Dual Channel support
* Support for up to 4 GB system memory
Integrated Video
* NVIDIA Geforce 6150SE
Expansion Slots
* 1x PCI Express 16X
* 1x PCI Express 1X
* 2x PCI
Ethernet Controller
* LAN 10/100 (Marvell 88E8039)
Audio
* High Definition Audio subsystem using the Realtek ALC 888 audio codec
IDE (HDD, ODD)
* 4 SATA II connectors
PC stock spec:
Specifications
Condition: Factory Refurbished
  Operating Systems:  	Genuine Windows® Vista™ Home Premium 32-bit
  Platform:  	PC
  Orientations Allowed:  	Vertical
  Form Factor:  	Tower
  Bays:  	2 - 5.25" Drive Bays
  	1 - 3.5" Drive Bays
  Internal Bays:  	3 - 3.5" Drive Bays
  Available 3.5" Drive Bays:  	1
  Available 5.25" Drive Bays:  	1
  PCI Slots (Total):  	2
  PCI Slots (Available):  	1
  PCI Express X1 Slots (Total):  	1
  PCI Express X1 Slots (Available):  	1
  PCI Express X16 Slots (Total):  	1
  PCI Express X16 Slots (Available):  	1
  PCI Express Slots (Total):  	2
  PCI Express Slots (Available):  	2
  Expansion Slots:  	4
  PS/2 Keyboard Connectors:  	1
  PS/2 Mouse Connectors:  	1
  Serial Communication Ports:  	1
  Parallel Ports:  	1
  USB Ports:  	6
  FireWire Ports:  	2
  LAN Ports:  	1
  Audio Out Jacks:  	2
  Line In Jacks:  	1
  Microphone Jacks:  	2
  VGA Ports:  	1
  Processor Brand:  	AMD
  Processor Class:  	Athlon 64 X2
  Processor Number:  	5000
  Processor Speed:  	2.60GHz
  Processor Interface:  	AM2
  Processors Supported:  	1
  Processors Onboard:  	1
  Additional Technologies:  	HyperTransport Technology
  	Dual-Core Technology
  Memory Type:  	Dual Channel
  	DDR2
  Memory Size:  	2x512MB & 2x1GB
  Total Memory:  	3.0GB
  Memory Speed:  	DDR2 667 (PC2-5300)
  Memory Slots (Total):  	4
  Memory Slots (Available):  	0
  Maximum Memory Supported:  	4.0GB
  Interface:  	SATA II
  Capacity:  	400GB
  Speed:  	7,200RPM
  Optical Drive Type:  	DVD±RW Dual Layer
  Interface:  	EIDE
  Type:  	Media Reader
  Capacity:  	15-in-1
  Media Types:  	Compact Flash
  	MicroDrive
  	SecureDigital
  	Memory Stick
  	Multimedia Card
  	Memory Stick PRO
  	xD
  Audio Description:  	Integrated Audio
  Audio Chipset:  	High Definition
  Channels:  	7.1
  Graphics Description:  	Integrated Graphics
  GPU/VPU:  	NVIDIA GeForce 6150 SE
  Video Memory:  	up to 128MB Shared Memory
  Video Interface:  	VGA (15-Pin D-Sub)
  Communications Description:  	Integrated LAN Support
  Interface Type:  	RJ-45 - Ethernet Connector
  Data Transfer Rate:  	10Mbps
  	100Mbps
  Communications Description:  	56Kbps PCI Modem
  Interface Type:  	RJ-11 - Phone Connector
  Data Transfer Rate:  	up to 56Kbps
  Power:  	300 Watt
  Mouse Type:  	Wheel
  Buttons:  	3
  Scrolling Capability:  	Vertical
  Connection Type:  	PS/2
  Keyboard Type:  	Multimedia
  Front Speakers:  	2
  Height:  	15.5"
  Width:  	7.25"
  Depth:  	16.5"
any input would be appreciated , I hope i put everything that is needed.
Thank you very much,
If my question wasn’t clear enough , can i use the ram i purchased (OCZ PC2 6400 1gbram x 4 800mhz) 4-4-4 @2.1v.)
… if so what will i have too do?
I get a blue screen saying there is some hardware issues when i use this ram ,and i get this error… STOP: 0x0000001a 0x00041287 , 0x1f9a3ea8 , 0x00000000 , 0x00000000
and when i put the stock ram back in it works , and my motherboard spec says this ram should work, i really do not understand , please help :doh:
Thanks,
