Oi I am new here and have a problem
i have 2 RAM sticks for 2GB(one for 1GB and second for 1GB to) computer worked fine for about 2 weeks.Well the problem is that when I pressed ESC on memory testing(on the beginning when booting).Its says press ESC to skip memory test so I did it and now when I have that 2 sticks for 2GB computer wont boot.Just a blacn screen appears when I turn on the computer.
boot with just 1 stick..then boot with another..see if your computer starts with either of them..i dont think memtest cud have damaged your ram..
^do what he said, and if that works, then try them in the other dimm that the ram was in in the first place, if they don’t work in it, then don’t use that channel any more.
