Hello there,
I am trying to remote a friends computer or vice versa. We got everything setup
- Enable remote desktop under System >> Remote
- Enable the port 3389 in my router or his
- Enable Remote control / Remote Management under the router
- Found the Internal IP address in the router (use it to connect)
- Enter the Internal IP found on the router to Remote Desktop Connection.
- Failed to connect
What’s the problem here? I have tried to connect his computer and he tried mine, but both doesn’t work. Somehow… One day I put a port range 3380 - 3390 in my router and he worked for ONCE… and then later on we tried it doesn’t work. (with the same configuration that worked perviously)
We both have a Linksys router, just different model. We both have WinXP pro installed on the comp. Anyone have any idea about the setup or anything I can do to make it work? Thanks a lot
