I recently changed my motherboard using this method… TweakXP.com - Changing Motherboards , (everything is working fine), and now I want to replace my Maxtor 60gb hd with a Seagate SATA 320gb…, I bought a sata cable, and a sata power cord, but their is another input on the hd; jumper block? Does anyone know if I need a cable for that, if so where do I get one?
Also, is there anything I have to know before replacing a hd, besides backing important files up. I plan on using this method to replace my hd… Seagate DiscWizard
if its a sata hard drive, then u dont need to set any jumpers as al drives has only one cable, however if its a pata, then just set the jumper to master which is printed on the hd. all u need to do is change the jumper position if u havent got a jumper, den get one off ur old hd
1.)its a sata2; is my motherboard capable of connecting at 3Gb/sec. (just click on “my computer” to see my mobo)
2.)And how can I connect at that speed, the pic exactly describes my hd, it has something on the outer side, and it seems like the only way I can connect at 3gb/s is to take off that part on the outside? but it seems like its molded in? What am I suppose to do
SATA hard drives are factory set for workstation/desktop
use. For enterprise storage requirements, the jumpers can be set to
enable spread spectrum clocking or power-up in standby modes.
So you dont worry about it. Sorry for distracting you. Just go ahead and fit your HDD in your comp. because you have everything required, sata cable & power cord. Leave the third pace as it is~!
