Right to left
Hi everyone, I am running windows XP home the default language is English and second language is Hebrew, my problem is I can’t get Hebrew to run right to left in outlook express or in the google bar. The Hebrew letters go from left to right and I can’t work out how to get it going the other way. It works fine in Open Office but that’s about all any help would be very gratefully received. Peter
Hi, Have I baffled all those great minds out there or do you need more information? Peter
in OE - don’t the standart formatting options work?
in Google toolbar - if you mean the search bar, then I’mm not so sure - I think that the alignment is pre-set in the code, although, I’d suggest you mail them for this. :rolleyes:
Hi, Tried all the formatting options all I get is hebrew going from left to right even when I click right to left document, I’m a little computer challenged so maybe I’m doing something wrong. Many thanks for the reply Edijs. Peter
