S.M.A.R.T Problem
Hi Guys,
When i started my system today i got a message
      "Pri Hard Disk:S.M.A.R.T status BAD, backup and Replace"
  Press F4 to to continue
and 2 error codes…
  1. 007C
  2. 0085
hard disk is 3 years old
these are the details:-
[B]
Device Properties:
Driver Description : SAMSUNG SV0802N
Driver Date : 7/1/2001
Driver Version : 5.1.2535.0
Driver Provider : Microsoft
INF File : disk.inf
Disk Device Physical Info:
Manufacturer : Samsung
Hard Disk Family : SpinPoint V80
Form Factor : 3.5"
Formatted Capacity : 80 GB
Disks : 1
Recording Surfaces : 2
Physical Dimensions : 146.05 x 101.6 x 25.4 mm
Max. Weight : 630 g
Average Rotational Latency : 5.56 ms
Rotational Speed : 5400 RPM
Max. Internal Data Rate : 562 Mbit/s
Average Seek : 8.9 ms
Track-To-Track Seek : 0.8 ms
Full Seek : 18 ms
Interface : Ultra-ATA/133
Buffer-to-Host Data Rate : 133 MB/s
Buffer Size : 2 MB
Spin-Up Time : 7 sec
[/B]
i booted my system after pressing F4 and ran Everest S.M.A.R.T test
this is the report
[B]
01  Raw Read Error Rate                  51   100  100          30  OK: Value is normal
03  Spin Up Time                         0    81   21         3776  OK: Always passes
04  Start/Stop Count                     0    95   95         5517  OK: Always passes
05  Reallocated Sector Count             10   5    5           208  Pre-Failure: Imminent loss of data is being predicted
07  Seek Error Rate                      51   253  253           0  OK: Value is normal
08  Seek Time Performance                0    253  253           0  OK: Always passes
09  Power-On Time Count                  0    100  100      443740  OK: Always passes
0A  Spin Retry Count                     49   253  253           0  OK: Value is normal
0C  Power Cycle Count                    0    96   96         4143  OK: Always passes
C2  Temperature                          0    157  94           27  OK: Always passes
C3  Hardware ECC Recovered               0    100  100    72143144  OK: Always passes
C4  Reallocation Event Count             0    12   12          193  OK: Always passes
C5  Current Pending Sector Count         10   253  253           0  OK: Value is normal
C6  Off-Line Uncorrectable Sector Count  10   100  100           1  OK: Value is normal
C7  Ultra ATA CRC Error Rate             51   100  100           0  OK: Value is normal
C8  Write Error Rate                     51   100  100         435  OK: Value is normal
C9  Soft Read Error Rate                 51   100  100           0  OK: Value is normal
[/B]
The only problem it has in S.M.A.R.T test report was
how can i over come this problem i am not able to boot without pressing F4
system also makes a beep before starting..is my hard disk really going to fail..is there no other option other than replacing the hard disk.
i am a nOOb in Hardware i dont know what is “Reallocated Sector Count”
please help me solve this problem:(
if you need me to give you any other Info please ask me…
[QUOTE=kneekill]
[/quote]
replace your HDD or you could disable S.M.A.R.T. in the BIOS
[QUOTE=kneekill]
[/quote]
S.M.A.R.T. isn’t kidding
[QUOTE=kneekill]
me neither[ot]i don’t recommend disabling S.M.A.R.T. in the BIOS[/ot]
BTW: backup your data ASAP
i backed up data even before posting the problem here..
i know i have to replace my hard disk..from the S.M.A.R.T message which i have got
i was just curious if i could overcome or solve this problem..in any way
[QUOTE=donkey]
Edit: extra characters to allow posting of this post
