I have a Asus p4c800-deluxe motherboard, running a intel 2.8c fsb800 ht, Thermalright sp94 heatsink and a 90mm fan. I use the Asus probe to check the cpu temp and I get 28c to 30c at idle. Is that a good temp at idle.
What program can I use to heat up the cpu.
What temp is safe for my cpu when it runnes a stress program.
That is what I needed to know. Thank You very much. What is a good program that does not take long to stress my cpu. I want to check the cpu temp differences.
Prime 95 is the quickest way. Otherwise, run some Folding @ Home. Besides a blatant plug to join the team, it really does heat the CPU up hotter than P95 does.
