I’ve recently bought a WD740 10.000 Raptor SATA HDD which I reinstalled my OS XP Home on. Now I wanted to use my old 2 PATA HDD as extra storage and backup for drivers and so on, and I thought I had it all worked out, that is until my computer started eiter rebooting itself or freezing completely. All HDD’s did show under My Computer
In the MMC under system logfiles I find a lot of error regarding controllererror on Device\Harddisk1\D.
I’m not sure how to resolve this, I’ve left the jumpers as they were initially so that’s one HDD set to Master and the other HDD to Slave, both are connected through the same IDE cable.
I’d like to know what I must do to make it work, additional info; my motherboard has a 3rd connector for another IDE cable.
For the moment I have disconnected the motherboard IDE cable with both PATA HDD’s, which resolves lockups and crashes, but that’s not the way the cookie crumbles is it?
im assuming the cd or dvd rom is alone in its own IDE channel? I didn’t really understand your first post, so here’s what I’ll do, put both PATA hard drives on the same IDE connector and the DVD on its own and set the hard drives to master and slave.
The problem arised when I had the cables set up as mentioned by you, the DVD has it’s own IDE channel and the 2 PATA drives were on one and the same cable and channel, one set as master one as slave.
Strange thing is, the error is about my D drive, which is the DVD rom, but the error description is; Device\Harddisk1\D.
At first I thought it was the SATA drive, but after disconnecting both PATA HDD’s the problem didn’t show up. Do the jumpersettings on PATA influence the SATA HDD?
I connected my DVD rom as master and the 1st PATA drive as slave on one IDE cable and insterted into the blue masterconnector. And the other HDD is set to master also but connected on the secondary IDE channel on the motherboard with a second IDE cable.
No more error entries in the log I guess this thread can be closed if nescessary, my problem is resolved.
