Hi, hope someone here can help, please!
I had two 120Gb SATA hdd set up in a mirrored array. The RAID is done in hardware on the motherboard (Abit KV8 Pro).
The other night, during a disk-heavy operation (un-raring a large archive) the PC slowed, and then locked up hard. When I hit the reset button the RAID BIOS kicked in and said there was a disk fault on the drive on channel 0, giving me the option to refresh the mirror or continue to boot.
First time round I continued to boot, which sort of worked but was really really slow. I never waited long enough for the OS to come up, I could see it would take hours.
Second time round, I rebooted, it showed the same RAID BIOS message and I selected to refresh the mirror. It started the refresh, displayed a progress bar and then just sat there, for an hour, with no progress.
I have tried both drives, singly (having broken the mirror) and together, in both the SATA channels, and I get variously:
- The slow boot
- A much faster looking boot, that unfortunately stops just as the Windows XP splash with the progress bar. When it does this, there’s an audible click (could be power, could be hdd) and then reboots again.
Thinking (hoping) it was the onboard SATA I went out and bought a PCI SATA card, and get exactly the same results.
I find it really hard to believe that both hard-drives have died at the same time, but I’m otherwise at a loss to explain why the results of using a different SATA interface.
Any ideas?
Tomorrow I will borrow an IDE drive from work, reinstall Windows on that, or maybe use a linux boot CD and see if I can access the SATA drives from an OS on a different disk.
