I am looking to build a desktop computer which will be used for programming and for gaming. With this in mind I am planning to make a computer that has a very good motherboard which can have additional or upgraded components at a later date. So essentially I want a future-proof machine that can last me years and years only needing to update the odd part if I ever need to bump the output.
I want to go for an Intel system because, well for no reason other than I like them more. I will have a budget of between £600-800 ($1100-$1500) depending of my finances after my new job starts. As I currently use a laptop nothing can be transferred across into the new system except a mouse and that’s not exactly a vast money saver.
So this is the system I’ve got planned but it’s still very much open to changes.
Motherboard
Intel D975XBX
(Intel® Desktop Board D975XBX Overview)
Costs £150 ($285) from OverClockers.co.uk
CPU
Intel Core 2 DUO E6400
(Overclockers UK Intel Pentium Core 2 Duo)
Costs £180 ($340) from OverClockers.co.uk
Memory
Corsair 1GB DDR2 TwinX (XMS2-6400C5)
(Overclockers UK Corsair XMS2) second bottom
Costs £76 ($144)
Hard Drive
Well I’m not sure on this as I’ve looked around and I’m looking for something in the 250-300GB range but only Samsung shows the actual size of the hard drive (300GB listed, 133GB actually!!!)
Any suggestions here would be most welcome.
Monitor
19” Hanns-G TFT
(19" Hanns-G HC194DP TFT - 8ms- DVI — tft dvi, 19 hannsg hc194dp tft 8ms dvi , lcd 8ms video from aria .co. uk)
That adds up to about £500. Anything else I’ll pick up as cheap as I can from places until I can afford better ones. This gives me money left to get things like DVD/RW, Network PCI, Keyboard, etc.
One final thing is the issue of the case, power unit and cooling system. Can anyone recommend good cases, power and fans? I have no idea about this part of the hardware…
Any other comments would be greatly appriciated as well.
Thanks,
Phil
