Does this happen outside of Windows (POST screen with all the letters and numbers at the very start when you turn your machine on)?
Also, does it happen in Safe Mode? Keep tapping F5 straight away after you press the power button to turn it on, select safe mode from the menu, select your operating system, and it will load into Safe Mode. If it happens there, you know it’s a hardware fault, if it doesn’t happen there, it’s most likely a software/driver/virus issue.
hihi
it aint related to pc or the gfx card
and to be sure i simply removed the pc cable and the creen still have problem(u know when it says verify connection bcoz cable is removed )
i’m thinking of voltage or something like that:dry:
