In order to set-up a network for a small business that consists of around 15 computers; what do you need?
I know you need a router, that comes with cables, but what else is there
You’ll need a switch to connect all the PCs, and a central server is a necessity. Take a look at SME Server for a domain controller and central file & print server. It’s super easy to setup, secure and license-free. You can even use it as a router if you like, though I don’t recommend it. If you impliment such a setup I can help out pretty extensively, as I have successfully deployed it for many small businesses already.
You’ll need a switch to connect all the PCs, and a central server is necessity.
coz u cant have P2P for more than 10 PC’s
damn!!! i didnt add the fact ure goin to need a switch, and a domain controller, for my assignment.
central file and print server-can that be part of your main server?-do you need software for that?
I guess Yes and its free as well and if you are worried about setting it up then …
OK, so this is hypothetical then. In other words, your homework? :doh:
lol, yeah, I’m taking Management Information Systems :read: as one of my courses; you’ll prolly hear from me again asking related questions.
I’ll keep that in mind if I do employ something like this in the future.:good:
