I’d like to know if you can change the amount of RAM that is shared. Currently it is 64mb. I want to do it because I have a 256mb integrated graphics card and it’s set at 256mb but when I looked on dxdiag it said it was only 64mb. Some people have told me that it would probably just slow my computer down but I have 2Gb of RAM so there’s plenty to spare.
Thanks guys
Are you positive its 256mb of ram? if so go into bios, somewere in the bios there should be an option to change i to 256mb i think.
Yeah Im positive its 256mb, I know how to change the aperture size, its the shared RAM Id like to know how to change. Thanks anyway mate ![]()
I know what you want to change, i just thought in some motherboards you could change the actual amount in bios, not aperture size.
Oh okay, nope I can’t do that with mine. I’ve emailed the company I got it from, they directed me to there tech support so maybe I’ll find out how. I’ll post it up here If I figure it out. Thanks again Willz
Ok NP, hope you get it sorted ![]()
