shuttle x case
Does anybody know of a safe web site were I can purchase “pc cube cases”. The ones that look like the shuttle x case or something similer
Please Help
Thank You
theres www.ebuyer.com they used to have quite a selection on there as safe as interenet shopping is apperently my m8s uses them all the time, i would if i had a credit card :smiley: you should check it out. hope this helps Dave
Well, you can’t buy the case alone, since they’re a custom design and have a custom fit motherboard. If you’re in the US, check out Newegg or ZipZoomFly.
Thank for help
[QUOTE=Dave35k]
I’ve used them is well, a bit slow with delivery but good company!
