i am very worried, in 3d mark 03, i got 6342 3d marks :o, and i dont know why, how is this possible, i have an X800XT PE, i used ot get 12,000
EDIT* very sorry, i found out that the reason i got that low of a score was becouse i have 16X AA enabled and 6X AF enabled in ATI control panel options, so i turned those off and then got 12,159 3d marks.
But i have got a problem, whenever i try to overclock my graphics card, i use the artifact scanner in the omega ATI drivers, i just leave speeds at stock, then start the artifact scanner, and 5 seconds later, loads of artifacts came on the screen, lines all over, then the screen went blank, and the graphics card reset its self, and this was on normal clock settings, do you think the graphics card could be damaged?
(sorry if i should of put this in the overclocking section, but i wasent sure which one to put it in, as this is a problem with my video card)
it seems like this is only the case with overclocking in the ATI OMEGA DRIVER overclocking utility, i tried rivia tuner, and it worked ok, so wahts wrong with my ATI drivers? :s
