sony DW_G120A
right ignor my previous post if found the problem kind of iv gone and bought media that aint supported by my drive which i find really silly anyway what do i do im updated the firmware to MYSYS3 and its still keeps saying disks are not big enough when there the same size as previously used mr.DVD, DVD+R4.7gb so is there away round it or have i just wasted 35 quid on 100 disks.
[QUOTE=gaz2374]
still keeps saying disks are not big enough when there the same size as previously used mr.DVD, DVD+R4.7Gb
did you buy DVD+r DL (dual layer) because DL disc can hold 8.5Gb[ot]or that’s what it says on the tin[/ot]
no, just keep em til you get a DL drive
iv allready got DL ones for my xbox back up etc but these are just 4.7gb standard (for films)memorex dvd+r 16x thats the only differnece between the memorex and mr.DVD was 8x but worked fine and these ones wont work
right then i have aquired some ritek disks now which are supposed to be the nuts anyway there doing the same getting to the end of encoding then saying the disk isnt big enough . could this be a nero 7 problem.
