Well my problem started with me taking a old Win98SE and install linux on it. Well now i want to put m win98 back but durning the change i had to get a new audio card. My old card was modem with audio output but it doesnt have any kind of label or name on it. so the card i have is a Creative Labs Sound Blaster Audigy SE. i have looked every were for the driver. Do you think that you could help me find it?
or an alternative is to fool windows into thinking i have a audio device im going to be playing same games on the computer but most of the games tell me that i need a audio device
its the only windows disk i have and i found my old audio card buts its not found its a really weird setup. the old card is a modem with a audio output that connectes to a 2nd card that you plug the speakers into. i really would like to get the game running even without sound, maybe a fake device would work?
Update: I got my friend to give me his windows 2k pro disc so im going to try that it should let my card work i will give a update on it working or not soon
Update #2: After installing windows2k every thing is working fine
