sound problem
i have restores someones computer, and there seems to be no cd for installing graphics, motherboard and sound drivers.
the computer is a 1.9ghz xp2600+
480mb ram
intergrated GeForce 4 MX GPU.
It is a MESH computer.
i dont know what the intergrated sound chip type is, is there anyway to find out?
Check the make/model of the motherboard, from there you can find the exact drivers you need. Use [google]CPU-Z[/google].
all i can find is that its got a Nforce 2 chipset.
Can’t seem to find any good info for that motherboard. Try http://support.asus.com/download/download.aspx?SLanguage=en-us and maybe find a similar model and try the sound drivers for it.
