right someone asked me to install speedfan cause he wanted to compare info, but it got me worried to see the lil flame next to the 127C- is that an actual temperature or the maximum temperature at which bad things happen? am I currently safe??
don’t worry, it’s only 52.77777777777778 celcius, start worrying if it spend most of the time over 60C (140 F) besides those software temp and voltage detectors are crap at best, however they do provide a good guide (thats all)
chill out / don’t panic
Edit: bug in speedfan 4.29, i presumed it was displaying F and not C as it says
Edit: try Sandra
